Help with k member info please
Kiwi383
9:04 PM
Auckland New Zealand
Hello to all, My partner has recently imported a 70 Charger from the US to New Zealand. We have just found the cause of a steering gremlin. The k member where the torsion bar is mounted has given out. We are going to pull the k member out and see if it is repairable but may look at replacing it if its too far gone. My question is, what other k members will fit. It is a 70 Charger originally a 383 4 speed car and now a 440 4 speed. I know it will have to be a big block k member but will E body big block k members fit? or does it have to be, just B body k members? is there a difference between years? and is a 383 member the same as a 440 one?Does it matter if its power steer on manual steer etc. Any info would be appreciated. Thanks in advance for all of your knowledge.
Crack in K Member - Torsion bar mount..jpg Crack in K Member torsion bar mount 2.jpg 20191124_173227.jpg
No difference between small block and big block K frame for 70 B body . 68-69 will work with out a front sway bar. The 70 sway bar goes though the k frame and the 68 -69 mounts in front. Earlier B body 66-67 will work also but the idler arm only has a single tab mount where the 68-70 have top and bottom. I believe E body will work also, but not 100% sure. Check Schumacher conversion website. Will tell you the difference in K Frames.
Steering angle is different on an E-Body. That's a one year only k-member. As mentioned small and big block is the same.
Thank you for you help, much appreciated
