chtampa
One thing to keep in mind prior to installing: the E-brake cable has to run through the driver's side connector so measure entry and exit point and drill an elongated hole on each side.
I drew a line across the bottom and then welded a tube large enough for the threaded end to fit through. I didn't want to worry about crap getting inside the frame.
