fuel questions
dickdale
4:17 AM
Europe
How much fuel flow does a 6.4l stock Hemi needs?
I've bought a Spectra tank, model CR9CFI with an intank fuel pump (through Rockauto.com) and it states that the pump has a flow rate of 68 gph -77 gph and a pressure of 55-85 psi. The Hemi needs 58.5 psi, so that's covered.
Also where did you guys placed your fuel pressure regulator? With or without a gauge? Or gauge at another location?
1/4 vs TIme to fill 1 gallon container
7 sec---- under 12 sec
8 sec-----15
9 sec-----20
10 sec----25
11 sec----30
12 sec----35
If you want to read the whole article it is on the Barry Grant web site.
Go to the fuel delivery section, then click on TECH SUPPORT. THe artilce name is Fuel Can Dcelivery Test or something to that affect.
As long as you have the PSI covered you should be good,
I located the filters and regulator up front so it would be a piece of cake to service. 3/8 pressure and return, SS hard lines and PTFE SS braided flex lines.
My system flows 340 lph @ 90 psi. FYI
Thanks!
The regulator and gage are Aeromotive products. Filters are from Summit racing, 10 micron replaceable elements
The Spectra tank has a Walbro pump, I think 225 LPH or 59.43 GPH.
It could be a 255 lph, I would have to check the archives from when I got my fuel tank. Most of those pumps will go 90+ PSI, but the current draw really increases. Regulator will regulate pressure to that ever it is set at.
