66plysat
- 3:22 PM
- Feb 11, 2010
- Rancho Cucamonga, Ca.
I've been fighting my electrical problems for a couple of weeks now. I removed the dash when the car (66 Satellite) was painted. I labeled the connections and put them all back together. I will list the problems.
1. No dashlights
2. 1st fuse (accessories) slot on fuse block has no power. All other fuses have power
3. Horn worked a couple days ago. I tried to remove the horn ring to check the connections in the steering column and couldn't remove the horn ring. Now the horn doesn't work.
4. I've read about the headlight switch causing problems with the electrical when the switch is bad so I replaced it with a new switch, didn't solve any of my issues.
5. New headlight switch and old one has a folding terminal on the case. I have nothing that connects to it. could it be for a ground wire. (1st & 2nd picture)
6. I have this under dash connector that I cannot figure where it connects (3rd picture)
I have other electrical issues but I'd like to solve these so I can permanently reinstall the dash.
1. No dashlights
