Small block auto to manual transmission conversion
Moparfiend
9:31 AM
HOT
Was wondering two things if I wanted to convert to a 4 speed:
1. what manual transmissions are readily available (including overdrive)? I hear stock 4 speeds are difficult to find.
2. what else will I need?
Bell housing/inspection plate
Flywheel
Z bar and brackets
Shifter
Manual trans mount
Different length drive shaft?
Clutch
Pedal assy
looks like an expensive list not even including the trans man.....
Complete kits from Passon Performance run about $3800-$4000. I would say that Brewers is about the same. You may be able to piece the stuff together for a grand less (just a guess) A used B body 4 speed with the Hurst shifter is on Craigs List,Mopar Parts,Lake Havasu right now for $750. Any good? can't say.There is a 4 speed crossmember in the for sale ads here.
Don't forget the Z bar support that is welded onto the inside (purple) of the frame rail and torque boxes in the corners
I'm gonna ask a silly question. Didn't mopar continue the A833 platform after 1974 in the form of 5 speeds? If so are they a direct bolt in? Not trying to hijack your thread just curious.
New carpet, shifter boot, reverse lamp and wire harness.
Was just curious. Lots of work and cash just as I thought. Think she’ll stay an automatic unless I win the lotto......
