- 6:19 AM
- Feb 22, 2013
- The Red Anvil Dog House
I guess I ruined my numbers matching 68 Roadrunner then.
Sorry purists.
Sorry purists.
My car is numbers matching, but it is the 383 magnum, 4 speed..."the little brother". Good collector value or great collector value?
Yes, very true. Always get a nice burn or three while doing frame connectors or any exhaust pipe welding.Welding upside down laying on your back is difficult.
Put that in the "negatives" column.![]()
With all due respect, bullshit.Those cracks in the top of the door jambs on B bodies are from repeatedly slamming the doors, NOT from the
lack of sub-frame connectors! The cracks start at the inside and work their way outward. Every time you close
the doors hard, the top of the quarter gets pushed in tearing the sheet metal a little bit each time. The sheet
metal gets work hardened and starts to tear. Mig it up from inside the panel and you'll be good for another 20
years. The cracks and busted out lead joint where the windshield posts meet the cowl are from the car flexing
from not being stiff enough.
No ****. I have the scars to prove it. Hard to make a pretty weld as well.Welding upside down laying on your back is difficult.
My welder ended up in the emergency room with an awful rash from scraping off the undercoating in summer heat. Ride was transformed. Amazing result with the welded USCartools.
I have no doubts that welding in subframe connectors on my stock '70 Charger 500 (383 magnum, 4 speed) would help stiffen it up, but at what point would subframe connectors be necessary? I am asking because I might stray away from the stock engine.![]()
I've heard of rear windows popping out of Road Runners and B body cracks/splits where the forward edge of the rear quarters wrap around into the door jamb.
