Stock 273's have a adjuster and no lock nut. Those are aftermarket or stockers that have been modified. Tap the engine over to the base circle and slide a feeler gauge between the valve stem and the rocker pad. If you have .012-.020 clearance it''s a solid. Hydraulic won't have clearance but you will have to back the adjuster off a half to a full turn to get to Zero clearance. Here's stock 273 rockers.
