PRHeads
- 2:32 PM
- Aug 31, 2018
- So. Burlington Vt
This is a 346 head, but will give you an idea......
If you do more than this for a mild small cam build, you’re probably wasting time and wearing out tools for no gain.
Stock pinch = .975”
Reworked pinch = 1.060”
The pinch work was a 7cfm gain.
(My recollection is that the 516 head has a wider pinch area than the later heads)
With a back cut OE 2.08” valve the port in the pics flowed:
237@.400/251@.500/260@.600
For comparison, a gently used 452 head(factory valve and valve job) flowed:
206@.400/222@.500/225@.600
For another comparison....... the big valve 906’s I had on my old 448, that made 535hp and ran low 11’s....... that I ported before I had a flow bench, and just used some guidance from a guy who did porting for a shop I was working at........ the 8 cylinder average(which I determined later on after buying a flow bench) was...... a whopping 239cfm.
I had spent quite a bit of time on those too.
Stock pinch = .975”
