funknut
40's ha, Add another 20 years and you'll know how I feel..
I know I shouldn't complain, but it's a natural tendency of mine. ;)
Those seats look really comfy. Should be able to drive quite a few miles without getting a back ache.Made some good progress today. Welded up a few small holes in the floor pan from sheet metal screws I used to hold the panels in place. Also drilled out and zapped a few areas In the rear floor section where there was some rust pitting.
Fumbled my way through applying body filler for the first time. I used Evercoat Rage Ultra and it was super easy to sand. I heard a lot of stories about filler that is rock hard but this was no problem at all. Depending on the weather tomorrow I will try to prime the engine bay and maybe the floor pan.
I also set the seat in place to get an idea of what I’ll need to do to adapt it to the original mounting holes. Looks like it won’t be too bad, the only bummer is due to the contour of the floor pan I won’t be able to hide them under the carpet. No big deal though, I should be able to get away with 1/4” x 2” steel bar so it should be pretty easy to hide once it’s painted.
Thanks for tuning in. I’ve been watching your build thread with great interest. Looks like you’re making some good progress!Great thread - really enjoyed reading about your progress. If it makes you feel any better, my '68 Charger has been off the road for 8 going on 9 years - your plan was much better than mine. Keep up the posts, they're great and I'm learning a lot reading through it.
A plan is only as good as the guy implementing it, and I have been known to get a bit off track![]()
There are some good threads on the process and I used this video to guide me.
