question on my fender tag
Dakotaacres
12:07 AM
ND
decoded my fender tag. 72 satellite I'm comfused on G2G verus E44. also FIX9 and A12.
any help?
RH23:
Plymouth Belvedere,Satellite
High
2 Door Hardtop
G2G: 318 150HP(net) or 155HP(net) 1-2BBL 8 CYL
1972
St. Louis, MO, USA
129828: Sequence number
E44: 318 cid 2 barrel V8 230hp
D34: Light Duty Automatic Transmission
EV2: Hemi Orange Exterior Color
FIX9: Trim - Luxury, Unknown, Black
A12: Unknown Int. Door Frames
114580: Build Date: January 14580
: Order number
V4W: Unknown Top Color
U: USA Specifications
G11: Tinted Glass (all)
H51: Air Conditioning with Heater
M21: Roof drip rail moldings
M33: Body Side Moldings
N23: Electronic Ignition System
R11: Radio Solid State AM (2 Watts)
V5X: Body Side Stripes, Black
26: 26in Radiator
G is the engine size in VIN, 2 is 72, and G is the plant. E44 is an engine code.
No idea about the others.
G2G. is actually three different things... Lets do it this way.. Your VIN number is RH23G2G129828.... It breaks down as
R = Plymouth Satellite
H = High trim level
23 = 2 dr hardtop 21 would be 2 dr post 27 would be 2 dr convertible
G = 318
2 = 1972
G = St Louis plant
129828 = Sequence number
E44 is just another way of indicating 318 but the decoder you used is using E44 from an earlier year since the 230 HP rating is gross not net which is correct for 72...
A12 they got wrong, it is the scheduled production date October 12th
FIX9 is the interior code F I have no info for since my knowledge is mostly 1970 & earlier... 1 is bench seat cloth & vinyl & X9 is black....
H = High trim level
G = 318
2 = 1972
G = St Louis plant
Thank you so much.
Could the F1 be a code for additional notes on a special floor material?
Either that or it might be a factory 'typo'
A12 Oct 12th
August is 8
Sept is 9
Oct is A
Nov is B
Dec is C
V4W is white Halo vinyl roof
F1X9 is cloth and vinyl black interior.
decode this one please
it's P1X9
there's rust spec on the curve of the P
P is premium on an interior code
Yes, untouched fender tag.
Dakota, by putting the @ symbol in front of a members name alerts them that they were mentioned in that particular thread.
Like this @Dakotaacres :thumbsup:
Member 69coronetrt is a plethora of information on fender tags.
I’m asking if what I’ve circled on your fender tag is done on all St. Louis tags. Hopefully he’ll chime in.
