To OP, valve guide seals are the likely cause. The tool shown in posts #6 & 11 works well with stock springs. The rope method really works, you need to hold the valve closed when removing the spring. I used about 6' of cotton cloths line, pull the spark plug, feed the rope in & turn the motor over by hand till the piston stops, compress the spring, remove the locks, install new seals, reverse process to re-install. I had cloths line, a lever style spring tool, spare rocker shaft, spare valve springs whenever I went to the strip. Changed many broken valve springs in the pits or staging lanes using this method. Won numerous races because I could change springs quickly.
