Montclaire
It's simple math and not worth dissecting every single word a guy says.
Put in the 1.99" piston and fine tune the desired compression ratio with the head gasket. That's what I'd do - cheap but no quench. For those that believe that all motors live and die based on quench, buy a 2.06" piston with a 13 cc dish. But then you're looking at balancing, and bushing the rods for the likely 0.990" pin.
Once the motor is apart and the measurements are done, its 2 minutes with a calculator, and 30 minutes in some piston catalogs to figure it out.
Yep. I’ll report back when I have some hard numbers.
