Since I am not very well versed in how everything works in conjunction to get a good running engine, I am hoping some of you more knowledgeable in that department can help me out.
So I had a 400 based stroker built, dyno'd, and tuned by a very respected builder. He put together a motor previously for me and it is great. This one, however I can not get to quit detonating. It happens all the time when the secondaries open, no matter if you gently roll into them, or hit it hard.
He sent it back timed at 36 all in at 3400 per his sheet. MSD ready to run with 2 medium blue springs. One odd thing about this is that when I checked the timing it came all in at 2500.
He had me back the timing down to 33 and then to 30. I put in the 2 heavy silver springs to slow the timing curve to be all in at 3950. Also had me replace the NGK6 plugs with NGK7's. The plug change didn't do anything, but the lower timing and spring change did help.
He thought my Carter 6903 mechanical pump was running out of flow when the secondaries open and causing it to go lean. Hooked up my A/F meter and saw that was not the case. Yesterday I installed a fuel gauge just to verify that. Found out that my pump was putting out 10.5 psi. Replaced that pump with another used one I had here and raised the float levels back up. Did a compression test, 3 pumps on each cylinder, warm with the carb wired open.
Last evening I went and bought 5 gallons of 110 octane race gas and dumped it in with the 11 gallons on 91 currently in the tank.
Now the thing runs great. No pinging/detonation and all dielsing/run on is also gone.
So my question is, with the info I have, do you think the compression ratio is too high to run 91 octane? Or have I been getting bad gas? I have bought it from 2 different branded stations over the course of 1.5 months, and put about 400 miles on the car.
