Totally agree. The thing is that the builder was given orders to build a motor that I could fill up with 91 octane 100% gas at any station in WI and have no detonation issues. That is why I am getting so frustrated. I didn't want a race motor.
I said the same thing when I ordered the rotating assembly for my 493.
I didn't want something that ran right up to the edge of knocking where 1 point of octane made the difference.
I wanted a street engine that was fast.
If a car is used 90% of the time for racing, mixing in some 110 Sunoco is not a huge inconvenience.
During my frustrating experience, I posted about it on several Mopar forums thinking that if I cast a wide enough net, somewhere in all of it would be the answer. I was stubborn and didn't want to pull the engine to replace the pistons. Instead, I put in thicker head gaskets.
It worked but I suspect that this engine would make more power with dished pistons and quench.
Also, I asked what I should expect to see as evidence of detonation when I pulled the heads. I was told to look for broken ring lands, sharp holes in the pistons as if they had been hit with an ice pick and chunks missing. Check out what my pistons looked like:
After cleaning off the carbon buildup:
Zero damage anywhere. No discoloration. The head gaskets showed no burns, no defects. I dealt with what sounded like detonation but there was zero evidence of it. The 110 leaded gas allowed me to run the timing back up to 35 degrees and the car ran like Jessie Owens with no knocking but with 91 octane, it was back to detonation sounds. This is a mystery that I never figured out. Why did it make knocking noises and show zero evidence? Was it because I always lifted off the throttle the moment I heard knocking? Was there no damage because I didn't push it enough to let the damage develop ?
Sorry to hijack...I just thought I'd pass this along for whatever it is worth.
