- 12:54 PM
- Aug 17, 2018
- Washington State
That's not really true. Larger bores sizes along will create increased heat production. But you are partially right. Only partially! Cam specs and timing all contribute more problems.
Used to run 20-50 GTX and never had a problem with starter drag. Are bearing clearances tight? How many amps is your starter drawing? Are your grounds and connections good?I've been running Shell Rotella 15w40 plus the Comp Cams additive but with the way the car cranks over so slow when cold, I wonder if the cold oil causes increased drag on the starter. I just changed the starter and it still drags when cold and turns over fine when warm. Seems that several here run the 10w30. I'm going to try that.
.002 is as tight as I'll ever use but shoot for .0025.Uh yeah.... it is true.
Too Tight Oil clearances for the 'application' causing Elevated Engine cooling temps is FACT !
We see it on the Engine Dyno all the time !
High Oil Temps from insufficient Vertical Bearing Clearance as per the application = Higher Water Temps as well.
Where do you think the dead-headed hydraulic Oil heat gets dissipated ? into the Air ?
We've even re-tested an Engine for another Shop that took it off the Dyno/Dis-Assembled.... re-machined increasing the Rods/Mains from .0010"/.0020" to .0025"/.003" .... put back on the Dyno and dropped Water Temps 30*F and picked up 15 hp no other changes.
Obviously Timing, Fuel Mixtures, general tuning issues etc., can also cause higher water temps..... those are all no brainers
But Overbore/Piston size typically not a factor unless actual wall thicknesses are insufficient heat sink... again here... for the "application" and heat loading.
I'll cast a vote for Valvoline VR-1 10w-30.
The mains are on the tight side.Used to run 20-50 GTX and never had a problem with starter drag. Are bearing clearances tight? How many amps is your starter drawing? Are your grounds and connections good?
You try to make a good argue mom ent but your still only partially right. Modern engines all run muc tighter clearances then ever before and Anaheim very well. Larger bore size and increased stroke still account for majority of heat production.Uh yeah.... it is true.
Although the 440 can produce decent cold or hot pressure, if I could do it over again I would have used half grooved mains vs full groove Clevite 77's. Didn't like the op with the standard volume pump, switched to a HV Melling and it's fine.Full groove does cost some oil pressure
and the two half grooves cannot carry the lode of a full width bearing
(each side of the bearing has a curve off of load ability near the 4 edges)
a big loss is oil to the top of the bearing
Why ford went to a Side Oilier
and why we grooved the block and side oiled at the parting line where there is some
eccentricity to get a good "oil wedge" for the hydrodynamic lubrication
Remember it takes good oil flow to take heat out of the bearings
so it's a balancing act between clearance and flow/ pressure
there are also od grooved cam bearings or we have a tool to groove the blocks so we can feed the cam somewhere around 3 oclock
The usual diagrams are for an inline engine where they show feed at around 4 o'clock
V8 has two higher pressure zones and they oscillate
cam moves all over the place
What about standard - half groove versus 3/4 groove versus full groove main bearings and there effect on oil flow resistance and oil pressure
Us 383 guys are limited on main bearings
