biomedtechguy
Accelerati Rapidus Maximus
- 12:43 AM
- Mar 28, 2014
- South Louisiana
@440rb thanks a lot! I've posted a few places that the easiest and "most likely to happen" way, because of needing a tire better suited to a manual transmission "hit" and a sidewall that has a little taller profile to have a little "more wrinkle" or "give", the best way for me to reduce my driveshaft RPMs is a taller tire...I'm not looking for top speed, just 1320 speed, at around 139-149 MPH which I may see the 139 mph end of that (roughly high 9's)
Doing a few calcs for ya and I can't see you going past 7k trap speed in 4th with a 28+" tyre and 4.10's...assuming your@3700lbs all in (all ally motor) and say 700hp it'd be 6388rpm in the traps. At 800hp=6679rpm and@850hp at 9.60's/140mph=6815rpm. And say at 900hp you'd still only trap@6947.
All this rpm theory is of course with the hp no's being there from the hit to the line which won't be the case for most of them?....@149mph and 1000hp you'd be going 7195rpm and 9.00's.
BUT having said that, I've had the same pair of Toyo Proxes TQ drag radials on my car since I first got the 9"x17" Aluminum Rallye wheels. I took a wild assed guess and selected the 315/35/17 Toyos because I needed to get 4 new tires for my 4 new wheels. They fit so perfectly the factory should have made them optional! (I know, tire technology wasn't like that then) My point is that these have served me extremely well, with the exception of traction at the launch at the track,
BUT
Rather than lay blame for all of the traction deficiencies on my tires, I suspected and have seen confirmation of:
**Weak factory leaf springs. I thought the rear of the car was "a little low" and the real indicator of their worn OUT status was when I put Mancini's TOP of the line pinion snubber on it, and on the FIRST run, which didn't impart any extraordinary forces on it given the modest mods to my current motor, and the rear axle wrapped up so badly it BENT the beefy part of the snubber bracket that mounts to the diff snout! With the addition of the Calvert split mono leaf springs and sliders, the rear of the Roadrunner has risen about 2½" !! I also haven't ever heated the Toyos properly, only spinning them up before the starting line. NOW I'm going to have a line lock, so I can do a better job of heating them up. I've added the Assassin bars and the HitMaster launch control.
My point is that I may find my 315/35/17s that I've enjoyed in so many other ways do a good job with all of these other additions. I'm thinking ahead though, and the stroker is going to need better tires, even if it's the 345/40/17 Toyos, or one of the offerings from Mickey Thompson. Just about ALL of those tires, including the 345/40/17 Toyos are a inch or two or more in diameter than the 25.8" tires I have in the 315/35s, so I'm all set with the 3" driveshaft.
THANKS TO ALL OF YOU! Order to Strange being placed Monday!!
