I have two responses to the tossed lifter/no oil pressure problem.
I had too short pushrods in my first solid roller cam motor, and an adjuster broke, tossed a lifter out, and the tie bar turned the other lifter sideways, chewing up the cam. The regrind gained about ten degrees duration, lost more than .100 lift, and lost 1/2 second e.t. (slowed down).
On the other hand, a friend bought a duster with a warmed up 440,727,d60 with a bad miss, and no oil pressure, for 25 cents on the dollar for what the car was worth. Yep, pulled the intake, put the lifter back, replaced the bent pushrod, went elevens.
