1970 Plymouth Sport Satellite from Junk to......
Looks like there is a small difference from the original pan and the new one. Can you see it?
Hinges need to be rebuilt as they are the original and have never been touched and the door is sagging and yup their is play in the door up and down.
Trunk is just about complete. Looks a little better than the old one huh? Was not to bad to do. In fact was kinda fun and certainly very gratifying! I want to give a special shout out and big THANK YOU to Bart K for giving me the trunk pan. Was a very nice of you Bart!
099DB814-628D-429D-B392-E183F51D55EA.jpeg A6F37A9A-807B-4DA8-A668-6C133F2B91C3.jpeg E12746FE-DDF5-4855-92EC-2EEE6AFDB9CF.jpeg
First thing is to get a friend to help you. Put a floor jack with some type of padding, old carpet, folded towel etc... on top of the jack head and support the door. Remove the bolts on the door first. They are right out in the open and when you reinstall the door will be the last bolts you put back on. After the door is off, you can access the body side bolts through the kick panel. Passenger side might require the glove box be removed first. Then take good close-up pictures of the areas that you will see in a few pictures that I will send to you to make sure they are reusable. I will also send you the page from a service manual on removal/installation. My email address to send pictures and correspond with is : moparleo@hotmail.com .
Leo
  • bbody1hinge.pdf
  • DOOR-HINGE-PROCEDURE.pdf
Leo
View attachment 968694 View attachment 968695 View attachment 968699
Thanks for replying back to me Leo! Thanks also for the info ~ look forward to working with you!
I always scrounged A Body or four door hinges. Same hinge, on a smaller (lighter door) so usually like new.
Pan sealed. Will paint it the body color when I paint the car.
When you only have two hands.....hinges are out and look good no cracks etc on the passenger side. If the other side looks good then they are going to get rebuilt by MoparLeo
1F704E19-F8C9-4668-AA24-A492E6769B4A.jpeg 040699BE-0C0C-4138-9C6C-C9F99FCBBA2E.jpeg
Going to come back like new or better I hope!
7406B59C-6331-42AF-8212-6248B49BF31B.jpeg A00824EB-3911-498F-B85A-B8CA3FAB8A88.jpeg
The rear hinges on the four doors are different from the fronts. And the A-body hinges that I see are cracked just as much as the B-body. Its not the weight that breaks them but they lack a door check/stop to keep them from overextending when opened hard. They cured it on the A-body in 73 with the same door stop as the E-body. With the lack of proper or any maintenance on the door hinges on all A, B & E-body cars I keep quite busy with all models. More A & B's because they made so many over the years from 1967-1976 A-body and 1967-1970 B-body.
Your hinges should be done tomorrow and shipped end of day or Tuesday. Thanks for your business and keep up the good work there. I had no son either. Made my interests a little one sided. 2 daughters that gave me 4 grandsons though.
Thanks Leo!
Well I pulled back the dash to remove the dash pad. I know some think its not so bad removing them with the dash in but I really don’t think I would go that way, especially if I have the windshield out already. Thanks Jim K for the direction on that one!
I got at all 6 stamped nuts but one got stripped and just spun. It was a real bugger getting off. Must have taken me 30 minutes for that one nut. I had to keep pulling the dash pad away from the dash simultaneously pulling up on the dash while spinning the socket. I spun and spun and spun. A few choice words were heard by my neighbors as they hung in the hot air. This is whats left of that stud.
Looks like I need another dash pad........
This is one that did not get stripped...
Little details. The monikers were really messed up by the previous owners kids who had tried repairing the car but had no idea what they were doing. I was able to remove bondo from this and repaint it. I used rubber cement to mask the silver letters. Never used it before for this but thought it might work well. Works great I used two coats of rubber cement and used primer first for the painted background.
815AA021-4268-4F56-9822-352115A41E85.jpeg DEE8D72C-9EC1-42AC-94FA-344F68C14EC9.jpeg
Had a broken are rest bezel. Not sure what type of plastic they used on this faux chrome part but I had the piece that broke off. In search of a better glue I wanted to try something that would fuse the two parts and not met or deform the part. Bingo this type of bonding agent works great. Stronger bond line than anything I found so far! Parts get fixed fast as well and should hold up over time and over temps cycles.
Interior color change has commenced from green to black.
18A898A6-ED79-4807-BBFA-77A2D210C786.jpeg 9DFB6429-2069-49E0-A501-9C555277E993.jpeg
Silver enamel paint sharpie does really nice trim work!
657AD584-C406-4006-B381-50CDF4DFCF31.jpeg 4FB5A70E-0F9E-41EA-BD0C-77808D8E4E0B.jpeg
