33 IMP
- 11:04 AM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
Swap in a four valve cummins with 75 lbs boost, and an eight speed trans?
Can a big block be built to make good power and still have exceptional fuel economy? I am just wondering if it can be done? What would it take?
A stock or super mild build, add centrifugal supercharger and a OD, use a light foot and get good mileage. Use of a bigger cam kills mileage, so, use Rhodes lifters and cheat....Can a big block be built to make good power and still have exceptional fuel economy? I am just wondering if it can be done? What would it take?
Personally, I think a lot is possible but like anything it depends on your goals. If you are wanting to get 30 mph out of one, well I don't think that will happen, they are too inefficient. However, 20 mph is possible I think but it takes some work. with modern technology such as good heads (aluminum) EFI and a system to control spark and fuel along with the right trans and rear gears as well as tires.
Read your reply after I made mine. But I agree. Though a turbo kit can/could be more expensive. (Speaking of quality parts and not chink turbos for $100!)In short, I believe building a dedicated turbo engine (not for insane power) is the answer.
There it is.Need boost or nitrous to make it happen.Economy and performance in a B motor can not be used in the same sentence.
Hey andyf, What is it you have going on there? What car, engine, specs, and cost if you care to share it with us. Looks like a great build.Something like this.
Define good power and exceptional fuel economy.Can a big block be built to make good power and still have exceptional fuel economy? I am just wondering if it can be done? What would it take?
Okay.Good power is 400 HP. Great economy is 15 city 20 highway MPG.
