- 9:48 AM
- Mar 28, 2014
- South Louisiana
Kiwi, thanks for checking in.
Other than highway driving and cruising around, I'll be turning right after braking at the end of my 1320 runs, so no, not really looking for "handling" per se.
Having said that, I sincerely believe that the stiffening, strengthening, bracing, and all new improved suspension parts and QA1 tubular K-member as well as the Borgeson power steering box and fairly high end shocks in the rear (and pretty darn good ones up front already) are going to make a significant, substantial immediately noticeable improvement in how the car rides and corners.
Look, my front suspension, in particular the UCAs, that are being replaced with SPC UCAs, and the rushed, kinda half assed work that was done 2 years ago October, have all contributed to a very sketchy death defying experience every time I've driven my car since. It was Cruisin the Coast 2018 that I heard a squealing sound and found the nut on one UCA had stripped off. My nearly new tires were showing the belts on the inside treads of both tires!! So the shop found a nut that fit, but they didn't know that a previous shop had put my steering wheel in unclocked, so he tried to make the wheel align straight by making tie rod adjustments and that was all WAY OFF of true center. Knowing I was going to revamp my front suspension, I didn't do anything about it. Last October, once again, the front tires had the same wear pattern, so on went another set.
Much to my surprise, those have also worn VERY badly in the few miles I put on them. So yes, it's going to track and handle and turn much better than ever, better than a dialed in factory original car too I think, and hopefully the tires I put on the front this time will last a few years!
