biomedtechguy
Accelerati Rapidus Maximus
- 12:45 AM
- Mar 28, 2014
- South Louisiana
This involves "our" (my wife's) 1965 Pontiac 421 Tripower in our 65 GTO.
We have made a lot of changes, but I'll focus on what matters.
Vintage Air AC system, CVF Wraptor serpentine belt and accessories system, and a model specific Cold Case radiator and dual electric fan and shroud assembly they recommended that fits..well exactly like it's made for the radiator and car, very nicely.
Their radiators are the "advanced design" large tube type, 2x 1" tubes and 2 row in the case of the one we have.
The Wraptor changes all of the pulleys and accessories down to the timing chain cover, as that is the "back" of the water pump. The Wraptor water pump has the best impeller vanes (cast, not stamped) and is aluminum for heat dissipation, and has a higher volume than the factory pump.
Here's the impeller:
Here comes the "Pontiac wierdness"...
There's a divider plate that is installed in the timing chain cover, and then the water pump gets installed over that plate to the timing chain cover.
Here's what that looks like, notice the dome shape and hole in the middle:
sorry for the small pic.
Anyway that dome shape and hole edge has to be spaced away from the impeller vanes as tightly as 1/10th of an inch, or the pump doesn't work efficiently and overheating is a common problem with Pontiac engines. Since I didn't do the work I can only go by what the installer tells me. He says the gap is less than 1/8th" but more than 1/16th". I'm going to have him bring a piece of test equipment by to test the pressure of the cooling system. The idea is if the water pump assembly isn't working properly because of too great a gap, and it's cavitating or the gap is too big, pressure will DROP as RPMs RISE.
He wants to remove the 2x 12" fans and shroud assembly and try the mechanical fan. I'm ok with that, but I believe the gap is too big between the plate and impeller.
Anyone have any comments on first hand experience using the Cold Case dual electric fans setup?
