A390 speed dodge 1975 trans oil
67belvedere/225
9:29 PM
montreal
Anyone know what oil goes in a 3 speed manual transmission for 1975 dodge tradesmen
it was red coming out so i'm thinking atf , ???, i don t what to use
thanks
I'd stick with ATF, especially up North if you drive the van in the winter.
wont be winter driving this for sure
but is that what was in it originaly?
I still have the 3 spd from my '75 Tradesman, and the manual for it. I'll take a look for it when I get home today...
Here's those pics of the specs for your Tradesman, from the original manual.
thanks dan , if you could be so kind the alignement specs if you have them
67b, I'll look, but I don't think those will be in the Glovebox manual. Will let you know.
Parameter MIN spec Standard spec MAX spec
Front Total Toe 0.13 0.25
FL Toe 0.07 0.13
FR Toe 0.07 0.13
FL Camber 0 0.5
FR Camber 0 0.5
Rear Total Toe N/A N/A
RL Toe N/A N/A
RR Toe N/A N/A
RL Camber N/A N/A
RR Camber N/A N/A
Left Caster -0.5 1.5
Right Caster -0.5 1.5
Left SAI N/A N/A
Right SAI N/A N/A
Wheelbase
Front Track
found this on a site . 75 with manual steering
I remember the first time I prepped/serviced a new Dodge with a three speed and found ATF. I thought it was some kind of a joke.
Removed a rear end cover on a new one and found no gasket, just black RTV. What? :)
