Lighthorseman
- 5:37 AM
- May 12, 2011
- Prince Edward Island
So, I did a 4-speed conversion on my '70 Satellite / RR clone, but because I really don't know what I'm doing, when gathering all the bits and pieces, I neglected to note that there was no clutch fork pivot installed in the bellhousing.
I put everything together and installed the engine and transmission, only to realize once everything is in that the pivot is missing. I managed to get the clutch fork out and the pivot installed, but now cannot get the clutch fork back in. From what I can tell, I need to compress the diaphragm spring-thingy that the throwout bearing sits against by about 1/4 to 1/2 an inch to fit the clutch fork back onto the throwout bearing, but I'm loathe to try to ram a screwdriver in there and pry it. Here are my related questions:
- Is there some way to install the clutch fork without having to remove either the transmission, bellhousing, or both?
- Has anyone come up with some sort of brainwave system of compressing the diaphragm?
