Parking light bulbs
Aron Gleason
6:27 PM
Washington
on my 67 coronet I'm having a hard time getting the parking light bulbs out. I dont want to break the bulbs as they still work, but when I try to push the bulb in the socket to twist it out. Its like the socket is frozen. Any suggestions?
Had it happen many times. I have taken pliers to smash the glass and then used needle nose pliers to grab and twist the brass bases out. Clean the socket with a small wire brush and penetrating oil, and use dielectric grease on the new bulbs to prevent the corrosion from happening again. But you are going to need new bulbs......:)
you could try soaking with penetrating oil for a day if you want to wait but Big Bad Dad has the tried and true method!
anybody with a boat trailer before led's has some experience at it!
Thank you. I'm in no rush so I'll use Penetrating oil to get them loose.
When you finally get the bulb out, get a Dremel wire brush bit. It fits perfectly inside the socket. It will remove years of built up crud. You don't need an actual Dremel tool, a regular drill will work just fine.
