74 Charger Fuel Tank Vapor Vent Valve
Hijinx
1:28 AM
New Jersey
On a 74 Charger fuel tank, that hump for vapors has a tube, this would be connected to the canister at the front of the car. Was not planning on adding this canister, installing a Holley Sniper EFI system and was not planning on installing that...
What can i do OR what have people done to be able to release the vapors but not connect it to the canister? Is there a check valve that can be used?
What’s the fuel pump you’ll be using with the sniper EFI? We used an Aeromotive (stealth 340 I think it was called), this has provision for a vent which we connected to a rollover check valve. I will try and find a few photos, or can take a few next time I’m under there.
I just ran a hose up into the bumper area on a few cars no smells no problem. You could put a breather on it way back when I was younger I'd just leave it open!
Haven't looked at it in over a year, i bought the Holley Sniper kit that included the pump, will look tomorrow.
Found it - here’s the rollover valve. I went online and found one that matched the AN-06 size line I was running from the pump, I think I got it from summit racing.
