1965 Coronet Radiator Shroud
GOLDMYN
12:24 PM
chilton, wi
Here's a picture of the new reproduction fan shroud I install on my 22" radiator. They were standard on 426 and not available on anything else. I had my radiator customized
and the shroud should also help my stock 383
Bargains , had to find., I did find this and had mine done. I hadn't even thought of getting it rebuilt till I heard a comment that they always leak. I'm rebuilding my heater box and this is the last item to get,
$85.00 and turn around time was 1 week
Here's a picture of the new reproduction fan shroud I install on my 22" radiator. They were standard on 426 and not available on anything else. I had my radiator customizedView attachment 1009372 View attachment 1009373 and the shroud should also help my stock 383
Std on 426 only??? I have one on the Rad in my 65 Coronet 500 that has the Poly in it...
Not sure what they came on but the factory didn't put them on many cars. Maybe a HD cooling package or something. I saw an original once in a wrecking yard and I thought I should grab it. I came back for it with some tools and it was gone. Never saw another one. They were heavy and crude looking but better than nothing. I eventually put a later model plastic shroud on my '65. It works great but of course it doesn't look original.
Look for a 64 or 65 Chrysler C body shroud. They came standard on all 383 engines AC equipped cars which most Chrysler C bodies had. Fit perfect in my 64 Polara. Got the 22" radiator, steel 2 piece shroud (2524984) & steel 7 blade fan (2780921) off Craigslist for under $200. a few years back. Good Luck
I've got a question. Does it matter which heater coil tube coming out of the firewall ( hose), goes to which water pump tubes, I know on later models ie 68-69 BB, there is a picture which shows the flow. I can't seem to find one for the 1965 B body Big Blocks. I appreciate any help.
Sounds like you need to buy a service manual.
As I stated in my text, there isn't anything regarding which hose goes where (that I could find). otherwise I wouldn't have bothered the forum, Thanks for your direction
