8 3/4 End play adjuster lock tab
FSM says back it off 4 clicks....008-.012
I guess we should make sure which case he has?
Yes .008 minimum for '69, (actually for '69 it's listed as .008-.018) but that slight change "should" be for the 489 case, with the cone differential?
.013-.023 was spec in '68, so 741/742.
They're simply giving you a starting point with the 'approximately 4 notches from zero'. If that gets it there, great...but I'd hope people check with a dial indicator (or the feelers).
So there you go @19 69 GTX you have the specs for both models, verify what you have first..
1969 FSM,
'68
1969 FSM,
'68
agree, right across the board. And of course, because I’m **** and like to check things, I did dial the 4 clicks and it was at .013”, good enough for me! Thanks for chiming in, the more info, the better the results!
does any one have an extra adjuster lock
Probably have one.....somewhere lol. I'll take a look tomorrow as I'm about to go in after being in the shop all day and the temp hit 97 a bit ago and dang.....screw that mess. Supposed to get cooler but when.
chi town runner found one, thanks for the offer.
