beanhead
Easily Offensive
I guess we should make sure which case he has?FSM says back it off 4 clicks....008-.012
Yes .008 minimum for '69, (actually for '69 it's listed as .008-.018) but that slight change "should" be for the 489 case, with the cone differential?
.013-.023 was spec in '68, so 741/742.
They're simply giving you a starting point with the 'approximately 4 notches from zero'. If that gets it there, great...but I'd hope people check with a dial indicator (or the feelers).
So there you go @19 69 GTX you have the specs for both models, verify what you have first..
1969 FSM,
'68
