David Kosin
- 5:55 AM
- Oct 11, 2017
- La Grange Park, Illinos
I have been working on the headlights for months. Got them to roll up/down but will only do so a couple times then they quit working again. Been testing everything. Did note this:
When i reset the headlights in the closed position, i checked the limit switch to which the plunger comes into contact. Using a continuity tester, i can see that the normally open switch is now closed and no continuity. If i run another cycle the headlights close, but now there is still continuity in the switch and they will not work again until manually reset.
If i roll the buckets down by hand i can hear the plunger depress the switch. After another cycle it seems like the plunger is not fully depressing the limit switch. I have heard others say that the brackets must be tight. But there is so little of the switch to depress even a minimal off set leaves the switch open. I am nervous about stripping the holding straps if i crank them down harder.
Anyone come across an issue like this, and if so what did you do?
