terrywalker
- 7:38 PM
- Apr 14, 2017
- Kennewick, Washington
I'm having a problem with installing the outer rear quarter window sweeps on my 74 Charger. I have the original I pulled out, a new Top Cat Brand sweep and a PUI replacement sweep. Original is the top bottom one in my photo, the PUI is the middle one and the Top Cat is the top one. I'm having a problem installing the two clips, marked by the screwdriver tips, in the corner slots. I've tried starting at either end and can't get the clips on curved corner into slots. Do I need to start in the corner with those two clips first. The PUI has the cuts so it can be shaped the easiest. The Top Cat is better constructed. Anyone replaced these and can offer me some help? Thanks. Also, installing the seal in the track above the door/quarter windows, do you use the weather-strip adhesive the full length or just on the front and rear of the seal ends? Thanks.
Terry
Terry
