The lack of resistance makes the relay thinks the lights are on and the doors open when the ignition is turned on. Drove me nuts fkr about an hour till I remembered that leds have no resistance.
The relay is not activated by any resistance need, just need the headlight switch signal as trigger to open doors. Relay ( so does the motor) will work even without headlights installed with plugs hanging around. Is a plain and basic relay without any light sensing need. Juts like horn relay, which even without horns you could heard the click of horn relay working and power leaving the relay, just going nowhere.
You can even disconect the motor, and relay will still work. IN FACT with headlights off the relay still feeds the motor to close doors and keeps hot that wire while ign system is in RUN.
If you got some troubles is not because that.
FALSE FALSE FALSE... you got another problem or something incorrectly wired. As mentioned the relay for the hidden headlight system will work even without lights installed. The hideaways relay just need the trigger from ign switch green wire. The hideaways relay works even with any of high and low beams activated the same because the trigger for it is before the floor dimmer switch.
Jus like a horn relay, it will put power out even without horns installed. There is not any sensing needed on any of both systems.
Now your going to make me go out and see if my 72 doors stay open with the headlights unplugged. And I made the relay.
My 72 will open and close the headlight doors all day long with all four headlights unplugged. Tested it today.
