- 1:53 AM
- Dec 31, 2020
- Ontario, Canada
I would like to hear thoughts from the All-Knowing Mopar Forum on adding aftermarket air conditioning to my 1964 Dodge Polara. I once installed factory set-up from a parts car into this, but it never worked right. So I have all the factory air vents and engine pulleys. One concern is that goofy fresh air outlet in the right side kick panel area. It is a big gaping hole, and I don't know what to do there. I see Jim Kramer has a repro duct that came with heater delete cars. I am leaning toward a system from Vintage Air over the set-up from Classic Air, mainly because I can get free shipping into Canada if I buy from Summit Racing. I see Vintage has a bracket set for 440 and a separate piece for cars using TRW power steering pump as mine does. I am concerned about clearance around wiper motor and glove box. I had all the old holes for factory set-up in firewall filled and body worked when I had the car painted, so firewall is a clean slate for new installation.
Both of the mentioned companies offer drop-in kits for 1966-1970 B-bodies but there is not one for 1962-1965. My car has a thick 22" radiator and metal shroud that has kept the 440 cool in the past, even with the old condenser in front of it. I need hot, cold, and defrost. Any help from people who have done this installation would be greatly appreciated. Suggestions regarding switches and placement would be good. I thought I could operate fresh air door with cable hooked to original hot/cold lever in dash. The instrument panel is still not installed in my car, to make putting in this air conditioning easier. Thanking everyone in advance.
