So you sprayed the whole bottom of the car with it, and then painted over?Lizard skin has sound and thermal coatings that are water soluble. I used sound in the cabin & thermal on the under caridge. I have a gun if you decide to go that way. Painted over it.
Hey Hunt I just found your update, (about the last page and a half) I don't know why I don't get an alert even though I am subscribed or watching your thread? Do I have to log in every so often or what??At this point I was thinking of replacing the lower radiator support with a USCT piece since I am in the stiffening mode. Couldn't find any in stock, so called them directly to find out when they would be available. Talked to John who I believe is the owner. Heck of a nice guy and very helpful. He told me that the radiator support would do nothing for me since I wasn't running coil overs, but did say that adding inner fender braces and welding the floor to firewall seam solid would. Apparently they have quite a bit of testing of these old Mopars and body flex. So that is the route I went. Same deal as the connectors and torque boxes - I pushed the shell outside and blasted the areas that will be covered up. Then epoxy primer before welding.
) It is interesting that John from USCT recommended "adding inner fender braces and welding the floor to firewall seam solid"I was surprised about him telling me to weld that seam solid as well, I never would have thought of that. I also appreciated him being honest and telling me that adding the lower radiator brace would do absolutely nothing on my application. I know of some that would try to sell their products regardless if it was beneficial or not to the customer.Hey Hunt I just found your update, (about the last page and a half) I don't know why I don't get an alert even though I am subscribed or watching your thread? Do I have to log in every so often or what??
Anyway, I made my own lower rad support, and will be adding the torq boxes and sub frame connectors. I was thinking of getting the inner braces, but kinda decided against it.
(you know, when is enough, enough?) It is interesting that John from USCT recommended "adding inner fender braces and welding the floor to firewall seam solid"
Now you have me second guessing myself!
Thank you for bringing us up to date, I appreciate you documenting everything and sharing
No new metal, just welded the 2 areas that TTI missed.I've been thinking recently of welding up the joints on my Charger.
Yours looks great.
Did you add any metal to yours or just build it up with weld?
My mistake, my mind was on exhaust. I don't add any metal to the 8 joints. The 4 a-pillar joints you can fill in good with weld, but the c-pillar and rockers I just tack till the seam is covered. Don't want to heat those areas up too much and take a chance of warping. That with the original spot welds is stronger than it originally was imo.Sorry I meant the 8 leaded joints on the body!
