1962-65 dual quad adjustment/tuning sheet from Carter
sam dupont
1:32 AM
USA
Ran across this sheet I have for my 3705s carbs
Hope these are easier to read.
I can read them just fine.
When you post a picture on here it will be in a slightly lower resolution in the post. But if you click on the picture it will appear in a different window with better resolution. FWI
Nice! Thank you much. Here goes, (can hardly wait for these answers) what is difference between a solid seat and a resilient seat on the 3705's?
Thanks again for posting.
JP
JP
You are welcome. I tried to write a title line that would pop up if anyone did a search for tuning on those carbs.
JP
The difference between the solid seat and the soft seat: solid seat is metal to metal (the screw in seat and the moving stem opened by the float pull clip) and the soft seat (basically the same EXCEPT for a tapered viton tip on the moving stem opened by the float pull clip). The best combination is the soft seat as it provides a more positive, tighter shut off and is less suseptable to dirt.
Great info on the Carter carbs...particularly the 3705SA on the 426 Stage III engines.
BOB RENTON
BOB RENTON
