- 12:22 PM
- Mar 28, 2014
- South Louisiana
I've had to be aware of oil out of the driver's side valve cover breather ever since I changed from the factory stock PCV and valve covers. I had that factory black breather that has some internal headroom height and "dual wall" design that only allowed vapor to exit via the vacuum hose + PCV valve.
My "new" (4 years old now) fabricated valve covers required a new PCV valve and I bought a nice looking breather. I found way back 4 or 3½ years ago that when I was at the track or on the highway I'd get oil coming out the breather.
At that point I discovered not just any PCV valve functions as it should for a particular motor, and I got a M/E Wagner tunable PCV valve, although I run it in fixed orifice mode, aka "max suck". That seemed to resolve the problem.
Now when I do a "test hit" AKA wide open throttle from launch thru 2nd gear, on 2 occasions, my dipstick pops up out of the tube a bit and the oil sprays out the top. I just recently changed to a new Mopar breather w/foam element to replace a similar (but not identical) one because the foam element in the one I had was oil soaked, dripping oil onto my valve covers, and I knew of no way to clean the oil out.
A friend suggested adding a longer tube height breather to prevent the oil from reaching the top of the breather cap so easily AND adding at least one additional breather. My valve covers ARE baffled under the breather hole, so no direct path up the breather.
He suggested having 4 breathers, 2 per valve cover, but that would eliminate my PCV system and I'm not going to do that.
Suggestions welcome, please help!
