Babyblue66
What kind of numbers have you seen this cam make? I didn't spend a ton of time on the heads. Definitely opened them up though. You also have to consider these are old pistons with well over 100,000 miles. Just a ball hone and new cast rings. It could've used some new bronze guides too. These were probably on the edge of factory tolerances. Too loose for a real performance engine. I could've spent a grand on the bottom end, resized rods, arp bolts, balanced, with some cheap cast Pistons a point higher in compression, 8.5 and made 1 hp per cubic inch and close to 500 ft lbs. Kinda wish I had. But it's good enough for now.Oh OK.... I've never seen a 'dish' 440 Piston ? Not say'in they aren't out there, just never had the pleasure I guess ?
I think you did very well Rebuilding/Porting the Cast Iron Heads to see the 415 hp from the whiplash.
