K frame swap
Rob Vaughn
2:23 PM
Will a 69 coronet k frame fit on 65 coronet 440?
Also are the motor mounts in the same position?
this change puts the engine 2 in. back,now you can use e-b body 66-74 headers and oilpans, whitch are much cheaper and more p
Trans x-member and mount will need some ingenuity. The newer k unit gets the engine closer to the firewall. Depending on what HVAC plumbing is there, you may have to move it too. I'm using a 70 unit on my car. Idler arm is different too compared to the 65. Engine mount brackets are different. You can see what I did in my thread "Updating the Super Street Mopar"
Can you send me the link? I can't find it
I made a cross member with the late model spool mount for my own use. Pretty simple.
Gives me some ideas on revising mine when I get back on the project.
