Testing cooling system n a/c
diesel_lv
Arizona
Well I'll finally get a good test of my cooling system and a/c next week. 110 last week and did well. Had a 115 day last yr w electric fans that did well in slow traffic and idle but horrible on interstate. But next week I finally get a real world test of my mechanical fan and factory shroud.
For reference, 383 stroked to 496, 610hp on dyno. 26" Entropy 2 row aluminum radiator. Each row is 1.25". Flowkooler water pump, reverse rotation due to serpentine pulley setup. Direct drive 11 blade 19" nylon fan from Chevy truck w 496. 180° Shaw style Mr Gasket thermostat. A/C is all stock inside car, under hood is parallel flow condenser, new lines, new dryer and compressor from '96 Durango. At 115° at idle it blows 38° at the vents.
115° ambient and 38° at the vent @ idle . No air through the condenser ?Wow !? A 77 ° drop is amazing. 57 % temp change.
Almost unbelievable. I always thought when doing customer a/c services that a 20% drop in vent vs. ambient was normal.
What exactly do your fans do at speeds above 45 mph ?
Maybe heat stroke/exhaustion?
That was last yr w the electric fans. Unfortunately on the highway, it would overheat. W the 19" 11 blade mechanical fan, I'm hoping for the same at idle. So far at 110° ambient it has. On the interstate w mechanical I'm at 176-184 cruising at 70mph in 110°. Again, next week should be the real test. Most modern a/c systems shut off w a certain high or low side pressure, not sure which. Definitely not an a/c tech. From what I was told, my system has a thermostat to shut off compressor when evaporator hits 34°. I'm definitely happy w it so far.
Well I'll finally get a good test of my cooling system and a/c next week. 110 last week and did well. Had a 115 day last yr w electric fans that did well in slow traffic and idle but horrible on interstate. But next week I finally get a real world test of my mechanical fan and factory shroud. View attachment 1122204
Welcome to Las Vegas NV !
Not as Zkrazy As It Sounds !!
Try doing anything outside in that heat ….
The Asphalt Is over 150 degrees!
I know people will disagree, but I swear by that combo.
I'd love to have a fan clutch too but w the serpentine setup there is no room. I know it'll wear out my water pump shaft/seal sooner.
I'm retired, own most everything, live on the St Clair River, and I'll be on my fishing boat today - in 86° weather - and that's pushing it! I'd literally melt away in 100°+ "dry" heat!
Unfortunately!!! Own "Everything" outright. No bills, retired 8 yrs. 1 mile from the Colorado River. Spend most of my time on my boat.
I "visited" Wisconsin 2-1/2 yrs ago during the polar vortex. -50° . I spent 23yrs in the Army in all conditions, rode a motorcycle in Las Vegas for a living for 18 yrs, but -50°, no thanks. Heat is miserable, Cold hurts!!!
Here's this week's temps. I'll be taking her out around 3 today to see how she does. Engine temp, a/c, stop n go n highway. Will update later.
