Power Steering Input Shaft - Seal Replacement
dadsbee
7:09 PM
Midland Ontario, Canada
Thought these pics might help someone down the line, as they make it self explanatory. Was leaking bad before our Fall 2019 trip to the 50th Anniversary of the Aero car in Alabama and Georgia. I added leak sealer and it got me this far, but it's been pissing on the floor since starting the car after Winter storage. I bit the bullet today, before a hopeful family Father's Day cruise this weekend with four cars. Hardest part was getting the coupler off the input shaft.
Just sitting and pissing on the floor.
Knocking the coupler split pin out with a long piece of round stock (from one of those plastic road side election signs)
Steering column unbolted at the firewall flange and holder bracket and pulled back until the reverse lock out lever hit the firewall on the engine side. AFTER THE COUPLING WAS ALMOST OFF THE INPUT SPLINE, OTHERWISE YOU CHANCE POPPING YOUR COUPLING/SHOE SEAL OFF!!!
Coupling pried off the input shaft.
Predrilling the start of a two holes to make getting drywall screws into the seal face easier. Everyone should have one of these drills, browse Ebag for yours..
Drywall screws threaded in lightly and they walked the seal right out.
New Federal Mogal / National 7188-S seal I picked up of Amazon.ca for 6 bucks with Free Shipping and it was delivered Fedex next day.
Electrical tape on shaft splines and new seal slid into place (lip oiled first)
11/16 deep socket and my tight spot hammer (a bucking bar I welded up years ago) to put the seal into place.
Coupling slid back into place and the split pin reinstalled.
Thanks for showing this procedure!
Make sure you don’t nick the shaft or the bore in the steering box with the drill or screws.
Old school always works.
Well no puddle on the floor today, so I guess it was a success! ... and yes I did fill the reservoir back up and run it yesterday..
Ok
will give this a try.
Working on a quarter panel issue, which is the priority, but don't need a new stain from moving in and out of garage.
My new starter solenoid and oil pressure switch came in today, so finished installing those today.
Ill order that seal from Amazon.
Thank you Dadsbee.
Super-bee I take it.
The seal you referenced is not showing up on my Amazon search.
So went to Rock Auto and found this one.
Is the name of this seal the Sector Shaft seal?
Rock Auto sector shaft seal
National 6859S
and a second one
BCA NS6859S
Yes this appears to be the same spot this steering gear box is leaking from.
No idea on those numbers. Numbers I have are NAPA#6141 and Master Pro #7188S (Federal Mogal/ National seals as well)
Fairly certain '66 and '70 boxes input shaft seals are the same, but something worth investigating..
Nice car and what a dream garage, wow.
Mine is a standard two car garage with one side taken up by another car, Comet Wagon V8.
My brother has a 70 Super Bee 440 six pack with the little scoop with an actuator.
He also has a GTX 440 six pack, with a factory special hood.
I'll go to Amazon and retry with those numbers, the pictures of your steering box looks the same as this one in the 66 Satellite 318.
Researched Amazon and the -
National 6859S Oil Seal same as Rock Auto came up - $40​
Rock Auto - National 6859S oil seal - $7.86
with shipping $17.00
Will order in hopes it's correct.
Amazon Timkin 7188S showing $19.41 so same price and delivery date As Rock Auto.
(Who do I want to support, makes no difference)
Will go with your picture and similarity.
The only question would be a difference between a manual or power steering car.
Confirming yours is power steering Car?
So looks like the - National 6859S Oil Seal is the correct one for 1966 Satellite 318 Automatic power steering box.
The Timkin 7188S is showing up as not compatible.
Will call a local parts supplier tomorrow.
