73LemonTwist
I have a lingering issue that is puzzling me, and maybe one you folks have an idea. Its a mystery puff of blue from the exhaust.
On start and warmup there is not evidence of blue in the exhaust. Under normal operation their is no evidence of blue in the exhaust, and the plugs are looking pretty clean - no evidence of oil buildup on the plugs.
When I take the car out for a run after its been sitting for an extended period or idling in the driveway for an extended period (ie tinkering with the carb), at the first stop light after the engine rpms have been up to a city cruise for a few blocks, I get a very distinct cloud of blue. its not a puff, but a noticeable (and embarrassing) cloud.
It happens once and then will not occur again until its next extended period of sitting. It seems to occur that first time you let off the throttle back to an idle.
The car has a PCV but no EGR valve. Compression is good and balance between cylinders is good.
I am baffled - ideas to check?
