Hellaphant ?
HellCat 6.2ltr. crate ?
426cid 7ltr. crate engine ?
6.4 392cid SRT Hemi crate ?
a stock 5.7ltr Hemi crate ?
Or you add a centrifugal supercharger
or a roots blower like Dennis H did
OR rebuild what you have
& bump up the cam & heads, tune & exhaust
all the typical stuff, & still get it to pass smog
(but maybe easier & cheaper to buy a crate deal)
I/We don't have annual smog checks up here "yet"
so it's not a big worry (until I want to sell)
but mines also not a Hemi,
it a 99 Dodge Dakota 4x4 SLT, not a Ram
just a measly Magnum 318/5.2ltr, has 60k on it now
but is still compliant thou, it could pass if need be
visual & sniffer
most if not all the parts installed
come with a (Calif.) C.A.R.B. certification too
* it has 1.7:1 HS rockers (1.6:1 stock)
* a Hypertech tune
(I can go back to stock tune or bump it up for better fuel too)
* Flowmasters 3" cat back exhaust
(I have some
bolt on, Chrome
Edelbrock shorty headers for it too,
someday I may even install them, I used my Summit Bucks to buy them
before they expired)
* an AEM swirl spacer under the TB,
bigger 4" air-tube inlet & air-box
kit, with a gauze cone type filter
It woke it up
big time just them lil' changes
especially driving up here at elevation
on
the flatlands like down there in the valley,
it was 'just OK' without all the added stuff...
It needed it up here...
I have slightly larger tires too 32"x11" vs 31"x10.5 factory
so far so good, some 50k+ on all them mods
it gets better mileage than OE too
Next for me is a gear change...
( 3.91:1 maybe 4.10:1 someday)
probably go to 33"x10" tires too, if I go to the 4.10:1's...
My only real gripe after the mods
(probably mostly is from bigger tires, but work great in the snow)
I don't like how it hunts for gears, between 3rd & OD, between 35-40
so I drive with OD off, until I'm on flatter areas,
or slower or faster than those speeds, where it's just fine...
Yours a gear change &/or converter too,
can make a huge difference also...
