Mark Barnes
Just looking for a reasonable HP/TQ range for a non-stroked 383. Any other additional power adders are fair game, just 'splain what you got.
Well said ,as always, Mr Porter. Completely agree.Use parts that are a good match for the intended use, and it will make what it makes.
As long as all the pieces are on the same page, it should make what would be “expected”.
Imo, you’d have to have a pretty serious type of build to warrant TF heads on a stock stroke 383.
Decent CR, big cam, big intake...... wanting to make some top end power.
I’ve only dyno tested a handful of 383’s.
I’d say the main reason for that is when the builds are in the planning stages, it’s usually a next to zero dollar upgrade to build a 440 instead....... and that’s what ends up being built.
I can’t recall ever testing a very mild 383.
Interestingly, the one that made the most power had the least flowing heads.
....... but had the biggest cam.
I agree, it IS interesting that the one 383 that made the most power had the least flowing heads.
Would you care to expand on why that may have happened, and what the "big" cam was?
I know that there is no replacement for displacement. I would have built a bigger motor if I'd had my druthers, but I had a 383 sitting in the garage and my son asked me to build a car with him. Done deal.
Copying an old build from a some book I forget which
600+ hp N/A 383
TRW 12.5-1 Dome Pistons
Weiand tunnel ram
2x 660 center squirters
600+ lift 300+ duration solid roller cam
Milodon pan and external oiling
Race ported 915s
Worked and polished stock rods
ARP rod bolts
Girdle
1-7/8 headers
To be run on E85 but the build I'm replicating was a alcohol motor.
My bracket build went a best of 11.26@119
8” converter, 4.56’s, 9 x 30 radial slicks, cal tracs, open headers.
Typical ET’s around that time were low 11.40’s. 60’ times in the low/mid-1.50’s(best of 1.51).
