Fresh build of a 500 stroker this spring, new Melling standard pressure and volume oil pump. Before firing the motor the first time, I pre-lubed with a drill motor, and was sort of suprised at how long it took to bring up oil pressure. That was 1,000 miles ago. Oil pressure was running 45 lbs at start-up and cruising speed. Recently it started acting like it was running out of fuel when I got on it, so started looking for issues. Swapped carbs, changed fuel filter, no difference. Today I pulled the fuel pump, and found the pushrod was wore down 0.140in. I replaced the pushrod with one I had, and changed the oil and filter. On start-up, no oil pressure and plenty of valve train noise. I pulled the oil filter, and it had no oil in it. Replaced it with a NAPA 1515, and still no oil pressure. What am I missing?
