Big Bad Dad
Working on my 64 Fury. I bought a new stainless tank and a new filler tube. The grommet came from ebay. (Too bad all this cannot be bought from the same source....) Anyway, I spent half the day trying to get the darn filler tube into the tank. NO WAY! I finally pulled the tank back out of the car so I could work unobstructed on the bench. It ain't gonna work. I can't force it in even when well lubed with WD40 and light motor oil. The tube fits into the old grommet in the old tank just fine..
Anyway, measured everything with dial calipers. The new tank inlet is 2-1/4" (2.250") The tube is 2". I can slide the grommet onto the tube outside of the tank. The inside diameter of the grommet groove measures 2.400". This makes it too tight to physically insert the tube. I am thinking the no name grommet from e bay is made wrong, and is too thick. (It is listed as working for my application, as well as most Mopars of the 60s and 70s.) Are my tank opening and filler tube diameters correct? You guys know of a grommet that will work for this?
HELP !!! Thanks.
HELP !!! Thanks.
