- 7:00 AM
- Jan 15, 2020
- Okeechobee, Florida
First off, I don't have a problem with the quality on either set; I bought the MRE/HS set first (MRE57001-15-714K) and then went to the Comp cams set - the Comp Cam set is far superior but they cost significantly more as well. $511 for the MRE/HS and a Summit price of $778.95 (1621-16) for the Comp Cams Pro Magnum shaft kit. The MRE/HS rockers have no offset, either intake or exhaust. Both sets come with all the hardware and are complete sets.
That said, the MRE/HS is for iron OEM heads like the 906. You can make them work on aluminum heads but you are going to really have to work them over to get a good intake valve tip to roller alignment, see pics (the MRE/HS units are red anodized and the mounts are blue anodized. The CC units are a business-like black/gray. The CC's Pro Magnums come out of the wrappers fully assembled and line up correctly (they are offset like typical mopar convention).
The steel CC's are bushed nicely while the MRE/HS units are aluminum and are not bushed. The CC's use a cup style adjuster, so you will need a standard ball-ball pushrod while the MRE/HS rockers use a ball style adjuster, so you will need a cup-ball pushrod for those.
I wanted to put this out there so you'll be aware of the differences before you buy. The MRE/HS units will be fine for OEM iron heads but if you want to use them on aftermarket aluminum heads (Stealth or Edelbrock, etc.) you will most likely need to do some heavy clearancing on the intake side pushrod holes. The other thing to consider is that MRE offers a 10 day return policy - I bought them and didn't open them up to fit them for a month, so that's on me. Anyway, check the pics for the story.
Chuck
View attachment 1172410 View attachment 1172411 View attachment 1172412
Chuck
