- 12:15 PM
- Sep 6, 2009
- Boulder City, NV.
The 3705 carb run fine they were designed specifically by Mopar for the Max wedge. The point is the AVS carbs do not have a large range of adjustment and all way tight on the spring = The still open quicker than the 3705 that have a heavy Weight on the secondary side - Which will cause tuning issues with no available Secondary Accelerator pump to smooth the opening transition. The Max Wedge intake with limited interconnection ini did run the max motor that way last year with the crossram and 3705's and it ran more than fine, instant acceleration. no back fire, no paint being burned,,i mean if u have something to say ................................................
the runners from Bank to Bank = has always been prone to a Backfire than most other intakes. That was the point I was trying to make with a bit of humor -
Not an attack on your abilities.
You asked a question on this forum and asked for our opinions and advise =
I attempt to answer it honestly as I could to the Best of my Knowledge of
my 60 years of Racing these cars.
Try the AVS carbs and let us know how work they in this application.
