Can anyone help me identify the 833 that I have.
It is a cast iron case with the long tailshaft that has both the B and E body shifter mounting locations.
The casting number on the tailshaft is C-99538.
The casting number on the side cover is C-95664 Z
The only numbers on the machined pad that I can make out are E106766.
The front bearing retainer is 5.125"
From the research that I have done, I believe it is an OD transmission because of the 5.125" front bearing retainer. But, I thought that I had read all of the OD transmissions were aluminum cases.
I was leaning towards getting the OD gear set that Passon Performance sells, but want to make sure what I have first to decide if it is worth spending the money to rebuild this one or not.
I can add pictures later today if it helps.
