426 hemi compression test results (cold)
Beekeeper
It’s a disease without a cure!
9:06 PM
Rogersville,TN.
I did a compression test on my 426H i did the test cold. Do these numbers look acceptable? this is the max number i got
cranking the engine with all plugs removed
and throttle wide open.
#1. 175 psi
#3. 185 psi
#5. 185 psi
#7. 190 psi
#2. 185 psi
#4. 180 psi
#6. 180 psi
#8. 180 psi.
#1. 175 psi
#3. 185 psi
#5. 185 psi
#7. 190 psi
#2. 185 psi
#4. 180 psi
#6. 180 psi
#8. 180 psi.
:thumbsup:
