Tee Ell
- 1:18 AM
- Dec 25, 2019
- Edmonton, Alberta, Canada
It’s a 1975 Charger 400 block edelbrock avs2 850cfm
Yes it isIs you choke opening when warm?
Sometime s this happens when your torque converter goes badYes it is
Hi thanks - no egr on thisDoes it have an EGR valve? If so, disconnect the vacuum hose from it an plug the hose then see if it still does it. If not, bad EGR. EGR valves can test good but be bad from a weak spring. This is the only way I've tested them that I know for sure. N it's quick n simple.
Hi thanks - can’t find a vacuum leak gas is new tank has been cleaned and lines replaced and the accel pump seems to be good. I’m wondering about that torque converter though - how can I tell if that’s the problem ?Sometime s this happens when your torque converter goes bad
I expect it to be a vacuum leak Bad gas or bad ground or no accelerator pump
Hi - no cat on this - thanks thoughDoes it have a catalytic converter?
Your symptoms
Sound like a clogged one to me
I’ll check that - thanks !Very low initial timing can do that also
Simple thing to check - carb to intake bolts. Make sure they're tight.
Check coil
Could be bad gas as Moparguy said. How old is the gas? It will run and rev but idle wants to stall.
Hi we have tried two carbs known to be good and bolts are tight - thanks though !
