I think the 361 4-barrel motors had 10.0 : 1 compression, but they are likely quite rare. They were the standard motor on 1962 Polara 500's. After Mopar started putting 383's in B-bodies, I think 361's came only as low compression 2-barrel motors. A good closed chamber head that would keep compression up would be the big valve/port "915" heads that came on 1967 440 Magnum engines. Again, these are getting hard to find. That 2 X 4 intake from a 350 will bolt right on a 361, just don't try to run too big carbs. Something like Edelbrock 500's would be good. The factory setups ran about 1/2" spacer under the carbs to keep throttle linkage from hitting intake runners. Classic Industries sells a repro carb linkage/kickdown bracket for 2 X 4 setup. The repro RoadRunner cam would be good at around .470" lift and 280 degree duration, with a nice rumble. Smaller motors like a 361 don't need as much cam as a 440. A 361 (and 383 and 400, for that matter) has a shorter stroke than a 350 Chev and will really rev with the proper breathing system.
My vote would be for the 2 X 4 intake, just because it is nice eye candy. I ran one on a 426 Street Wedge in a 1964 Polara 500 convertible I had. Whenever I opened the hood, it drew a crowd. I found a guy in Arizona or New Mexico that reproduced the "Football" air cleaners in fiberglass. Good luck with your project.
View attachment 1191185 View attachment 1191186 View attachment 1191187 View attachment 1191188
